Afternoon,
I have British Gas currently working to remedy this fault but thought I would consult some of the knowledge on the forum as a solution seems to be illusive at the moment.
The boiler has been fine for just shy of 6 years (from new) until a few weeks ago the 'F2' (Flame Loss) fault was showing. I have a Homecare policy for convenience so called them out for a visit to investigate. After switching the boiler off for a while and allowing things to dissipate it would fire and function fine for a short while before locking out to 'F2' again.
A few new parts were fitted including the condensing trump/sump (which had a slight crack) and my Annual Service completed but success was short lived. They have since revisited again, checked electrodes, the condensing pipe and drain itself and confirmed everything is A-ok. I have no slow flowing drains for that matter in the house, no gargling noises or bubbles coming from the boiler either and to our knowledge no air-block in the condensing pipe.
Having back-filled through the flue the condensing trap does drain but there is a delay/slow causing the F2 fault and/or the L2 fault (Flame Loss).They are re attending tomorrow with another new condensing trap/sump and new electrodes to be thorough.
I have thought of asking to try by-passing the existing condensing pipe and just run something temporary in to the adjacent sink, to guarantee flow is not restricted upon exiting the boiler assembly, but this isn’t an area of expertise for me.
I don't expect the engineers to be a walking encyclopedia for all boilers but if anyone has any suggestions I could share that might help pin-point the issue I'd be grateful, especially as a cold snap has arrived
Thanks,
BennyC
Thanks,
BennyC
It seems to need time for things to dissipate before functioning again, short lived for around 30-40 minutes. Case on or off makes no difference.
