Ideal loop setup?
24 Aug 2007
Just bought some new bits
240mm x 80mm Alphacool NexXxoS Radiator
360mm x 80mm Alphacool NexXxoS Radiator
Single Bay XPSC reservoir
XSPC Laing 18W DDC-Pump 12V DDC 3.25 - ULTRA PERFORMANCE
1/2" ID 3/4" OD Masterkleertubing
5 x Scythe Gentle Typhoon 1850
NZXT Switch 810
This will be cooling a 3930K with the idea of cooling my next two video cards as well
What would be the ideal loop setup/direction for this?
Is this adequate for cooling an overclocked 3930k and two video cards?
Loop order doesn't matter long as the res is before the pump. So searching for a few switch 810 builds and see how they have laid it out.
It should cool whatever you throw at it.
