Ideal PSU for new build
The Bitfenix Whisper M series are very worthy of consideration too. They are very keenly priced and all have 7 year warranties. What components are you looking at? As long as you are not going SLI or Crossfire 550w would be more than enough. If you are going multi card then that would depend on which cards you will be using.
My basket at Overclockers UK:
They are very well priced for fully modular, will have to find some reviews on them...
I won't be crossfiring or SLI my build....
I'm looking at these parts
Inwin303 case
Intel i7 CPU (not sure which one)
16GB DDR4 Team Group Vulcan 3000mhz
Corsair SP120 Fans x5
1tb HDD
250GB Samsung EVO ssd
Corsair H110i
That's what I'm thinking so far will order majority of it tonight
