ideal response 120 boiler problem
30 Apr 2011
cheshire
have a problem, not getting any hot water or heating.
the boiler has power and when you run the hot tap or switch the heating on the heat exchanger gets hot but no hot water comes through the tap ?
pressure is fine.
is it possible that there is a blockage somewhere ?
just thought i would ask on here in case there are any plumbers online :)
