- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
TT eSports Challenger Gamers Keyboard @ £26.99 inc VAT
This keyboard offers a unique cooling solution for your hands when the heat of the battle takes its toll on you. Allowing you to game under many different conditons you will be razor sharp at all times.
- Interface: USB
- Operational systems: WindowsR 7/Vista/XP
- Number of Macro keys: 6
- Number of Multimedia keys: 7
- 2.0 USB port: 1
- Switch lifecycle: 10 Millions
- Cable length: 2m
- Body dimension (LxWxH): 480x 205.5x 25mm
- Fan Speed: 6,000 RPM(±15%)
- Max. airflow:2.7CFM
- Noise level:21.7dB
- Rate voltage: DC 5.0V
- Life expectancy: 50,000 HRS
- Body dimension (LxWxH): 30x30x10mm
Was £36.98 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
- Interface: USB
- 2.0 USB port: 1
- Cable length: 2m
Was £36.98 Inc. VAT
ORDER NOW
