Ideas for case modding
17 Mar 2005
Oxfordshire
Currently I have the 650D fully cable managed etc, and most of the components/cables etc are black which has been fine so far.
However I was thinking of a contrast to the black without going down the neon route, perhaps spraying fans with UV orange and same goes to the 24pin and PCIe connectors.
Reckon a 10cm UV light hidden out of sight would be enough? And also any ideas you have tried would be interesting, cheers.
I'd go for subtle white leds. UV is for clubs :D
White cabling (corsair or bitfenix) would give you the contrast you are after. Then any white fans or white accented fans.
YOUR BASKET
1 x Corsair Professional Series Gold AX850/AX750/AX650 Individually Sleeved Modular Cables - White £52.99
1 x BitFenix Alchemy Premium Modding LED Strip - Connect White 30cm £16.79
1 x Corsair AF120 Performance Series Low Noise High Airflow - Single Pack £13.99
1 x BitFenix Spectre PRO 120mm Fan - All White £11.99
1 x BitFenix Alchemy 24pin ATX extension 30cm - White £8.99
Total : £113.45 (includes shipping : £7.25).
I would probably go with the corsair fans with the white ring, as I wouldn't want to overdo the white.
Edit: obviously I put the basket there to show the kind of things I meant..
