- 12 Mar 2008
Hi,
First post here!
Over the coming months I want to put together 2 PC's. Ones for me ones for the wife
, probably same spec but what I learn from building the first might effect how the 2nd one.
I'm hoping I can get some advice here on the spec I want, possible prices, hiccups and any new hardware I should wait for on the horizon.
First the spec.
The work we do is pretty graphics intensive (including video editing), and I like to play the occasional game now and again without it slowing to a crawl!
So I'm thinking..
775 motherboard, wth headers for front USB and firewire sockets, and SLI. - Budget about around £140
Not sure if I should have either a AMD or Intel processor, whatever fits best with the rest of the system I guess and gives me the most bang for my buck. - Budget around £120
Memory, 2GB - budget around £60
Graphics card, ideally I'd have 2 running in SLI, but I'll go with 1 if its going to end up giving me more power and I can add an identical one later one to get them running in SLI. - Budget around £200
PSU/Case/DVD Writer/Hard Drive, all of those would be the best I can get within a budget of £200
Total Budget - £720
Questions about the above are..
I'm a first time builder so a bare bones system that I can just plug the graphic cards into might be a better option, but I'm not afraid to get my fingers dirty and do it all from scratch if its going to save me a fair bit of money.
Thanks for any advice!! I'll report back here with how it all goes!
First post here!
, probably same spec but what I learn from building the first might effect how the 2nd one.I'm hoping I can get some advice here on the spec I want, possible prices, hiccups and any new hardware I should wait for on the horizon.
First the spec.
So I'm thinking..
Total Budget - £720
- is that a setup that's going to last me a few years?
- Will it play the latest games?
- Is there any part of that setup that I should wait to put in because theres going to be something better just around the corner to use?
- Are there any technical issues that I should be aware of with the above setup?
