ideas for this..
24 Jan 2007
hi there, i had an old computer given to me and just needs a few more things adding to it before i get rid lol.. i fixed all errors i was getting and give it a huge upgrade, the only thing it lacks are 2 things... memory and a DECENT (not expensive) processor.. i am a software guy really so try explain any ideas to a good understanding LINKS ARE PERFECT !!
i AM looking to buy these ASAP ! links would be helpful !
Thanks in advance !
Spec:
http://www.jetway.com.tw/oldweb/evisn/product/p-4/p4mdmp/p4mdmp.htm
^^^ a processor that will fit that !
pc2100 is *** it says on the memory stick
as i said ANY help would be great !
does :/
in the link is this info:
FEATURES [SPECIFICATION]
Support Socket 478B processor for Intel PentiumÒ 4 (mPGA478) package processor ,Support 400MHz System Bus Frequency
VIA /P4M266 and VIA8235 chipset
On-Board VGA
Support 184-pin DDR DIMM
On-board Lan controller
USB2.0 Support
Support Ultra DMA 133
PC'99 Ready & PC'99 Colorful I/O Ports Design
Support USB Controller & PS/2 Mouse , Standard IR (infrared) Function
Provide extra " three-wire" fans connectors
Magic Frequency Setting
Jumperless
BIOS Write Protect function to avoid Virus crash data
PC Health Monitoring On Post Screen
Magic Install
Y2K Compliant
ACPI Supporting For OS Directed Power Management
