So I'm in a modern build house (timber frame style)
I am looking at drilling a hole for a hook to hang a mirror in the downstairs toilet however I am a bit worried about hitting a pipe.
I can see where the stud is due to a very slight and almost imperceptible bit of the wall which a screw is obviously behind however this is slight off centre from the sink (about 1cm).
The Flexi pipes for the taps come out the wall around 18" from the floor level and in the center of the sink.
The floor is a concrete pad that was laid on to the foundations so, is it likely that these pipe go into the wall and then go UP to the ceiling and clipped to said stud?
Should I just accept that the hook will be slightly off centre and drill into the stud so I can be sure I won't hit a pipe?
I don't have access to a pipe/wire/stud finder
