Hi all,
I am trying to source a replacement DC fan to repair my electric cool box.
Spec:
Distance between mount holes: 88mm
Fan Diameter: 75mm
Fan depth: 17mm
Overall diameter (inc base "ears"): 110mm
Overall depth (inc base): 25mm
12v DC 0.16A
"Yu Jie Electronics & Plastics FTY"
Above dimensions are not essential since the fan mounts inside a larger plastic shell (coolbox lid).
Spec:
Fan Diameter: 75mm
Fan depth: 17mm
12v DC 0.16A
