identify this temp please... its running hot!
22 Nov 2005
this is on my father in-law computer. was wondering anyone can tell me if the temp shown "50c" is the cpu temp or the motherboard temp please. Spec is an Intel(R)celeron 2.8Ghz with 448MB RAM
cheers. not sure what the max temp intel(R)Celeron D run @ but when i try to convert avi files to dvd formate it raise to 67c i guess this is abit hot. the pc itself was bought from PCWorld not custom made. should i clean the thermal paste and reaply with better one such as AS5?
On my Ultra-D temp 1 is my CPU temp (it's easy to tell which one the CPU is at it's the one in minus figures ;)). However, on my old motherboard it was temp 3, so I would imagine it changes from board to board.
My celeron 2.66ghz used to run very hot as well with the stock cooler, about 70degrees under load! I changed the cooler for an artic cooling freezer 4 (or 7 if you have s775) and the load temp went down to 50 degrees. a big improvement!
