We have a PVC front door. The lock works that if you are on the outside and close it you cant just pull the handle down to open it, you have to use the key.
Personally I hate this setup, but I've no idea what its called.
The inside handle is a normal looking pull down handle but the outside is a short handle that ends in a square shape. I know its a bit vague but does anyone know what its called? I would like to know so I can try to find a normal handle/lack to replace it.
