idiots guide to DIY pc
I agree with Dom86's (above) build, but if you need to bring that budget down, swap out:
Toshiba 2TB 7200RPM SATA 6/GB/s 64MB Cache HDD - OEM
for this:
https://www.overclockers.co.uk/seag...64mb-cache-hdd-oem-st1000dm003-hd-334-se.html
It'll save £15, 1TB should be plenty for what a 13-year old needs - its enough for me, and I make games.
He doesn't need a disk drive with the above spec, but its worth checking that he doesn't have any games on disc that he can't download (he should know this). Unless he has Blu-Ray films to watch, and no access to a PS3/PS4/XBox One, stick with a DVD drive. They're much cheaper, and you can stream just about any film in HD these days on Netflix, etc.
Also - Windows 10 is a must over Windows 8.
Above build has some upgrade headroom later, but its also a damn-fine specification for right now, it should have no problem tacking just about any game he throws at it.
Hi again. my son really wants these. will they work
Asus H81-PLUS Intel H81 (Socket 1150) DDR3 ATX Motherboard
Stock Code MB-581-AS
16 In stock
1
£49.99*
£49.99*
Intel Core i5-4590 3.30GHz (Haswell) Socket LGA1150 Processor - Retail
Stock Code CP-534-IN
10+ In stock
1
£155.99*
£155.99*
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9)
Stock Code MY-299-CS
ETA: 20.11.15
1
£39.95*
£39.95*
Gigabyte GeForce GTX 960 OC 4096MB GDDR5 PCI-Express Graphics Card (GV-N960OC-4GD)
Stock Code GX-171-GI
10+ In stock
1
£158.99*
£158.99*
EVGA 600W 80 Plus Power Supply (100-W1-0600-K3)
Stock Code CA-025-EA
18 In stock
1
£39.95*
£39.95*
Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003)
Stock Code HD-334-SE
50+ In stock
1
£38.99*
£38.99*
Samsung SH-224FB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM M disc compatible
Stock Code CD-162-SA
30 In stock
1
£14.99*
£14.99*
Bitfenix Nova Midi Tower Case - Black Window
Stock Code CA-220-BX
50+ In stock
1
£26.99*
£26.99*
Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
Stock Code SW-172-MS
20+ In stock
1
£79.99*
£79.99*
really appreciate your help so far and i got my son to look at all your suggestions but wants the above.thanks
I believe that all looks good.
One thing is does he need a optical drive? games are all digital downloads these days using either Steam, Origin, Uplay etc.
You can get Win10 on a USB drive for £85.
Is that Samsung thing on the list above an optical drive?
And whats that youve put "win 10 on a usb drive"?
Thanks
Awesome, this is an ace thread.
I sincerely hope 'smiley son' is going to post some build photos. And make his Mum the odd cuppa tea for such a wicked rig :p
