idirect3ddevice9present failed:device lost (d3derr_devicelost)
10 Aug 2007
this error keeps comign up while trying to benchmark
any ideas what it is
step's i've took to solve are reinstall drivers make sure all drivers are uninstalled.
i've even formatted the pc and its still happening.
could it be the 7.8 drivers?
Apparently F@H can cause those symptoms.
Are you folding when benchmarking?
Essentially the message means that the device has been lost & cannot be reset at this time. So further rendering is not possible.
If the F@H isnt the cause, i would try an earlier set of drivers just to see.
I got the same error, at the time was due to the fact my cpu (Overclocked) wasnt getting enough volts...also tight memory timings and undervolted memory can also cause it
