Idle CPU usage fluctuation
26 Aug 2006
My 2600k shows constant fluctuation of CPU usage of anything between 1% and 15% when its just sitting idle on the desktop. Is this normal?
Yes.
There are always back ground services happening. Think indexing, virus application and/or all the crud that Windows packs into their OS.
You can use system manager to see which application or services are running if you like.
Thanks, thats a relief! Never took much notice before, but I've got one of those CPU usage gadgets and the usage just seems to jump around constantly, as does the idle temp (8 threads blinking between 30c - 37c).
Makes sense what you say though, glad its normal :)
