idle GPU on open test bench
27 Jan 2022
UK
I'm just wondering, some reviewers have an open test bench and others have a test setup inside a case.
Is there much temp difference between the open test bench and no airflow vs inside a case?
The reason being some crazy semi-passive future build depends on your answers :)
This is only the idle temps though, load temps the fan will be running so won't be a problem.
thanks
Depends on the case used but an open air bench means everything will have access to clean cool air, while a case the cool air will generally only come in from a certain direction and may be under/over pressured depending on the fan setup.
