Idle/Load temps for ym q6600
1 Jan 2008
Hey,
Just got my new mobo, PK5-Premium, whacked in a q6600 with the heatsink that you get with it and im getting idle temps of 56!
Is this normal? I am going to get a different cooler soon (i.e this week) but was worried about these temps anyway.
Also I have a huge range of temp across the cores, core 0 normally has the highest ( I think that is normal tho) and currently that is at 56, while core 3 is at 45! Is that normal??
p.s what is a good thermalpaste to get?
Thanks for any advice
Not sure, my temps on my E6400 idle at 52 and raise to as high as 59 under load. - that's using an artic cooling free pro 7 cooler.
It really depends on a lot of things, case air flow, thermal paste, temperature of the room...
But definitely if you can, get a better cpu cooler.
Hey,
I would make sure that all 4 legs of the cooler have been inserted correctly.
Good point, might not be cooling a quarter of the cpu. Will have a look now.
My air flow is pretty good i think Have a ton of fans in my massive thermaltake kandalf case. Im only using a stock cooler and paste but getting a new one this week. Just thought i would be running a bit cooler than this.
Oh yeah, room temp isn't that high, but its not the artic in here.
