22 Oct 2013 at 12:42 #1 Tattooed Tattooed Associate Joined 14 Aug 2003 Posts 2,002 Location cyberspace Hi, My neighbours having a problem with ie being bigger than the her screen. I have tried dragging ie down a bit. So she can use the URL bar. Her monitor is a wide one. How do I sort this problem.
22 Oct 2013 at 13:36 #2 linktoinsanity linktoinsanity Man of Honour Joined 5 Oct 2008 Posts 9,009 Location Kent Drag it down and double click on the title bar at the top. It will then maximize to the size of the screen.
22 Oct 2013 at 14:02 #3 Gambisk Gambisk Associate Joined 22 May 2013 Posts 1,229 Location N. Ireland Also worth a shot it "Windows key" + "Up Arrow" to full size the current window if you cant grab the title bar for some reason.
22 Oct 2013 at 21:15 #4 Tattooed Tattooed Associate OP Joined 14 Aug 2003 Posts 2,002 Location cyberspace Hi, Thanks for the replies.
