IE Favourites
19 Jan 2005
Romford, Essex
My MB has gone kapput and I have to buy a new machine. Alas I have failed to make BU's.
The HD is OK to salvage data and would like to know if there is a file in Windows or Program Files from the old HD which would give me my Favourites from IE. Thanks.
Also would OE have a file with old emails on. Cheers again.
On vista, IE favourites are stored stored in "C:\Users\Asim\Favorites".
For XP it's "C:\Documents and Settings\Asim\Favorites" IIRC.
Thanks for that Asim. Is that file transferrable to my new machine?
Is there a similar one for my OE emails and contacts?
BTW for XP Home
Yes it will be transferable.
Search for *.dbx in system and hidden folders and you will come across all your OE files, your contacts should be in a .wab file.
On your new machine, setup OE first, then exit, search for *.dbx again and copy your backup over, and do the same for the .wab
Kimbie
