IE issue
24 Jul 2006
Essex
I've noticed that a lot of webpages aren't working/loading properly and I keep getting a yellow triangle in the bottom left corner of the browser which gives me the following error message:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; InfoPath.3; Creative AutoUpdate v1.40.04)
Timestamp: Sat, 29 Jan 2011 16:55:55 UTC
Message: 'undefined' is null or not an object
Line: 517
Char: 5
Code: 0
URI: http://www.java.com/share/op/oo_engine.js
So this issue obviously relates to Java but how do I fix it? I tried updating Java to the newest version but that hasn't helped and if I search in google I just get pages of results regarding coding which is way over my head!
I haven't had much luck with IE, I can't really help with your problem but I can suggest you use something else like Chrome or Firefox. And make sure your Windows is up to date.
Have you tried resetting IE? There's a button for it in Internet Options.
What version of IE is this?
