IE site problem
16 Dec 2004
Isle of Wight
I am trying to bodge together a portfolio site for myself. I have got so far and all seemed to be going well. That was until I tested it in IE. Up till then I had been using firefox and it all looked right.
If you look at it in FF:
http://www.itsabeast.com/portfolio/level_design.php
Then in IE you can see IE adds a big gap at the top, it wrecks the side recent work picture. It also doesnt support png transparency which is a real kick in the teeth for my design.
Any ideas what I have done wrong here?
:|, that is odd. This is what it looks like for me:
Ok, theres a cell/line where you get that gap, if you remove it, it won't be there ;).
The PNG issue, is only a problem in IE 5.5/6 so will be fixed in 7+, so unless you really want to change it, don't bother. If you do, this will be usefull (I think) http://koivi.com/ie-png-transparency/
The recent work problem, seems to be related to spacing, the right side of the border is being hidden by the side of the cell.
