IE11 issues with OcUK Forums
10 Jun 2006
Northumberland
Not sure how to word this question but here goes.
I am having some issues with using the OcUK forums with Internet Explorer 11. I don't seem to get the subscribed threads link on top bar and I am sure its there when I use Firefox.
Any ideas or do I need to explain my issue a bit better :D
Well its worked for the forums but the OcUK website doesn't work properly. I remember now why I installed Firefox.
It only appears at the bottom if you have Javascript disabled (that's how vBulletin works with nojs clients).
So enable your javascript and quit blaming the browser for your settings :p
it's not that. i see the same issue as the OP and i know javascript is not disabled in my browser.
Compatibility View Settings > add overclockers.co.uk to it. The links will then be back to the top.
