IE11 problems.
Man of Honour
17 Feb 2003
Chelmsford
Anyone else been getting problems the last few days with IE11.
Drop boxes disappearing.
Can't upload pictures to FB, photobucket, Flickr.
Online banking login does nothing..
Just the last few days.. It's defiantly IE11 because all works fine with Chrome.
I've had a few emails over the last few hours from people i know complaining of the same issues.
Tried compatibility mode?
Overall though IE11 seems to be a pretty bad browser. I usually like IE (IE10 is fine), but this iteration looks to be a bad one.
Not sure why you would suddenly be experiencing issues, an update maybe?
Have you tired the same sites without add-ons ?
+1 I had very similar issues with IE11 using work applications, however disabling addons (NitroPDF being one) brought things back to life.
Just to throw it in there, NitroPDF was causing issues with a Java applet application so make sure you try without all.
dacads said:
IE11 is the problem
Stick with Chrome
Yeah wondered how long before this would show up lol.
None of the problems your having here with my ie11.
If it's only just started happening then look at something you may have done or maybe something you picked up in the way of a virus etc
Posted from Overclockers.co.uk App for Android
When installed ie11, OcUK forums worked in compatibility mode, but the shop didn't!
Anyone else have this problem with ie11?
