IE7 Command Bar issue
Caporegime
21 Apr 2004
Bristol
How can I reset the command bar back over to the right hand side?
Yes I've been playing with GPO's but the command bar dosen't want to move :confused:
I've tried that / there's no gpo in effect and it stays like that, tried the IE reset from inside IE too, no joy.
Create a new (temporary) domain user and then log in as that and see what IE7 does. Alternatively log in as that user on another computer.
Sometimes when you enable a group policy setting and then disable it the original change stays in place but you now have the option to change it back - if you get me.
Let us know if it works.
I know what you mean about the disable / enable thing, looks like its effecting me - now to work out where somethings been changed in another GPO. :(
