ie7 help!
23 Jan 2007
Glasgow
ive got an issue with ie7 in vista x64, it wont allown me to install adobe flash or shockwave, ive tried everything but both wont install. The problem only occured the other day when i re-installed vista as was working no problem before that. Is there any way i can uninstall ie7 then re-install it?
cheers
for flash : i get the error. ie7 has blocked the site from using active x control in an unsafe way
for shockwave : could not load the DLL library
I would have an educated guess and say, they still havnt made flash for x64 yet?
so when your IE x64 trys to install it, its throwing a wobbly.
You should be able to use 32bit version of IE however, that should install flash fine.
does that help?
does that help?
unfortunately not, still getting blocked by ie7
