IE7 history
Man of Honour
29 Jun 2003
Wiltshire
Hi all,
Does anyone know if IE7 history is kept in a text file? I've looked in \documents & settings\user name\ but can't find anything there.
Cheers
Go to Documents and Settings / Username then go to the folder options and enable hidden files and folders to be displayed.Now go to Local Settings / History...it's all in there.
Yeah already looked around those folders, but can't find it. The only things in Local Settings is Application Data and a Temp folder. No sign of the history folder / file.
It's there..providing you're using XP. :D
[edit] Woah...huge pic alert
