IE7 & IE6 possible?
Man of Honour
Man of Honour
3 May 2004
Kapitalist Republik of Surrey
I want to give IE7 a go here at work but our software doesn't run on IE7
Is it possible to do a side by side install so that both can be used?
i just installed IE7 stupidly thinking that IE6 would just remain any way. Now i want to downgrade back to IE6 (i'm a firefox user and i only use IE6 to check websites i'm trying to design). Can i do this easily without using a system restore? Anyone care to point me in the right direction?
Sorry if i'm hijacking the thread :(
You might need to click the 'show updates' box at the top of the add/remove programs window to see it.
