IE7 Problem
23 Oct 2006
Newcastle, The Toon
I recently installed the update for IE7 and will not connect once its open. I use many torrent downloaders and now when i try and open them it opens up a IE7 screen which states it cannot connect. I am currently using AOL and thier software. Is it possible i can just uninstall IE all together as i dont use it.
Thanks Ryan
try unluging ** router from the net for 30 seconds plug it in try again
system restore to before ie 7 was installed
if u dont wont to use ie yes u can just install it or just ignor it and use other programes like mozilla firefox etc
