IEEE 1394 Firewire PCI card
27 Jan 2003
Bristol
Got the above card and the PC can see it installed in device manager with correct XP driver. However, when I plug a DV Camcorder in, I hear the usual sound of a connection but the PC does not recognise the device or see it connected. ( Windows Movie Maker )
One strange thing that happened once is after a while, the device was finally recognised but the onboard sound card was then turned off ?
When I unplugged the device, the sound came back ???
This has only happened once though ?? I am confused with this.
By the sound of it I can only assume a resource conflict somewhere. If possible try moving the card to another slot or switching it with another card currently in there.
