IEM help
1 Dec 2009
Staffordshire
what IEMs can you get for under £100 without piercing highs?
i have only ever tried single armature iems, is that the problem? iv been looking for a dynamic iem for rock/metal but no luck.
what do you guys recommend?
Im have the same needs as you right now, I have a few im looking at but I have found Sennheiser IE8 for £90 from a certain online DVD store. cant beet that for value IMO, i will be buying a pair after xmas
Cheapest I can find them is £99, and not direct from that company but one of their 3rd party sellers. To be honest at the massive difference in price I'd be more than slightly wary that they'd be fake.
hmmm, looks like they have gone up in price by a tenner, you may be right on them being fake, guy only has 2 feedback and 1 is negative...shame
here are some that i have put on my short list, all are rated well and fit the bill more or less for fast paced metal that both you and i listen to:
Etymotic ER-6i
Denon AH-C551
Sennheiser CX 95 Style
Brainwavz M3 IEM's
Sunrise SW-Xcape
the etymotic pair have great top end clarity but apparently not quite as much hard hitting base but i put it on the list as it suits the other types of music i listen to :)
