- 26 Nov 2011
- West London
Have you got any easytune set up controlling the fan profile? It might be that the software will drive a very low voltage that your fans just will not switch on at. Fans can be a bit unpredictable at lower voltages. In the right conditions they may start spinning at say 5v, but then other times not until 7v. You got a link to the exact fans you are running? Also, what fans are plugged in where on the mobo?
