- 18 Oct 2002
- UK
...does that make my milk 'semi skimmed' or just watered down?
and what if any would be the difference?
thepedster said:...does that make my milk 'semi skimmed' or just watered down?
SunaseIPs said:You're not making some kind of bomb are you?
thepedster said:no, but a recipe says semi skimmed milk, I only have normal milk, so I thought by adding some water to my milk I would reduce its fat content overall leaving me with what would be pretty much semi skimmed milk, no?
Le_Petit_Lapin said:Why do you want to do this anyway?
Just use it as it is. Its not going to kill you.
My sentiments exactly.Haircut said:What's the recipe?
I'm sure using full fat milk instead of semi-skimmed won't make all that much of a difference.
Just because you consume fat doesn't mean you'll get fat.thepedster said:protein shake tbh, wouldn't want to get fat and muscely at the same time![]()
