- 24 Mar 2011
- Kent
Thursday just gone, I'm riding to work as I've done hundreds of times over the past 10 months. I turn right at the same set of lights I always do here https://www.google.co.uk/maps/@51.1...m4!1e1!3m2!1sAX0NLRCN0WkCEIqG7BoaZg!2e0?hl=en into a 40mph downhill stretch at which point I realise that the white Audi in front of me is stopped dead in the road, traffic I think. I start to brake, then think "Ok, I'm not gonna stop in time" and squeeze the brakes a little more...
Front wheel locks and (I think, can't quite remember) the tyre slides a little with the bike upright before pitching me off to the left with the bike sliding down the road and me doing a roll or 2 before springing back up while cursing the air something blue!!
Road where I went down:
So, in short, the CB400 went down, poor little bugger. Luckily there was an ambulance literally 50ft away waiting at the lights I'd just turned at which swung around and checked me out. Apart from my heart going at 120bpm I had a sore thumb (checked out in the hospital less than half a mile away, I kid you not!) and a bang to my right hip which is fine now. The thumb (right hand) is a bit of ligament damage, nothing more - and apart from it being sore and swollen and wearing a splint for a while, I'm unharmed.
Good kit does make a difference
My Furygan Duke trousers had both knees scuffed pretty badly, yet my knees are 100%, not a mark. Helmet has some light scratches on the visor and the right sidepod (Arai) so won't need replacing. Boots have a tiny scuff on a toe slider and my jacket suffered a scuff on one of the presstud covers
The bike suffered more damage than me and my kit:
Dent on the tank, about 4-6 inches by 3 inches. Not sure what to do about this, a crash bung wouldn't have saved it with the way the tank is shaped.
Broken gauge casing (replacement casings ordered off ebay from china) - stripped them and tested the clocks and apart from a missing pin where the speedo needle sits they work perfectly.
Smashed headlight glass and rim, bulb works fine - found the replacement parts, just need to find them in stock somewhere.
Gear lever folded right in on itself, mirror scuffed/barend scuffed and forks twisted in the clamps (but not bent, they hit the lock stops and the bar dug in so just need a little more straightening, they're only a couple of cm out now)
Scuff on the left hand engine casing, where there already a small scuff.
Oh and a fuse had gone. And I'm gonna need to reset the clock on my gauges
Overall, nothing major and all easily fixed apart from the tank dent.
I was going about 20-25mph when starting to brake so probably hit the deck at 15-20mph, now... if only I'd had ABS...
But.. it could have been a lot worse. It was a wet, damp and grimey road under some trees and tbh I've never been fond of the front tyre on the CB, so that may get changed for a pilot 4. In a bit of a dilemma as to how much to spend getting it fixed up, I'm TPFT so no insurance claim, half of me wants to sort it out properly but it's my every day bike which sees all weathers (and I'd rather put the money towards a fun summer bike to keep nice) so it's not worth getting it really nice, maybe in a year or 2.
As I was taking bits off yesterday I took a look at the chain/front sprocket (got a paddock stand delivered on Thursday) and the front needs replacing as well as the chain as it has at least 2/3 stiff links, so that'll get done too, and I'm gonna be on the lookout for a replacement exhaust as the pipes are blowing a little right under the engine, mild steel pipes which are 14 years old so no big deal, just hard to find bits for the CB400 as it's not a UK model.
So, TL: DR - I fell off, ABS would have stopped me falling off, so to anyone who says it's not worth it...
No major damage to me or the bike, just an annoyance having to take the train for a little while to work!!
I'll post a couple of pics tomorrow/next couple of days, the bike front end (clocks/headlight) as well as gear lever and sprocket cover are all off and it's sitting under a cover at the moment. Oh and to top it off, when inspecting the chain/sprockets, I think I found a nail in the rear tyre!
Hmm, where's cheapest for a set of pilot 4's...
But.. it could have been a lot worse. It was a wet, damp and grimey road under some trees and tbh I've never been fond of the front tyre on the CB, so that may get changed for a pilot 4. In a bit of a dilemma as to how much to spend getting it fixed up, I'm TPFT so no insurance claim, half of me wants to sort it out properly but it's my every day bike which sees all weathers (and I'd rather put the money towards a fun summer bike to keep nice) so it's not worth getting it really nice, maybe in a year or 2.As I was taking bits off yesterday I took a look at the chain/front sprocket (got a paddock stand delivered on Thursday) and the front needs replacing as well as the chain as it has at least 2/3 stiff links, so that'll get done too, and I'm gonna be on the lookout for a replacement exhaust as the pipes are blowing a little right under the engine, mild steel pipes which are 14 years old so no big deal, just hard to find bits for the CB400 as it's not a UK model.
No major damage to me or the bike, just an annoyance having to take the train for a little while to work!!I'll post a couple of pics tomorrow/next couple of days, the bike front end (clocks/headlight) as well as gear lever and sprocket cover are all off and it's sitting under a cover at the moment. Oh and to top it off, when inspecting the chain/sprockets, I think I found a nail in the rear tyre!
