If Threadripper wouldn’t be better at games, why does my cpu constantly run at 4.8ghz?
10 Jun 2017
on certain games my cpu runs at 4.8ghz constantly, moving up and down slightly.
I have a 1080 and that doesn’t even get bothered by the games.
I have a i7 2600k.
When I read benchmarks often a highly clocked 2600k doesn’t come much off a 6700k.
So why would it be so high?
This just makes me think any new i7 will be running like that on certain games. So maybe a Threadripper would be better, at least it has more cores to unload all that data.
You can't just "unload" all that data - there are significant portions of a game's pipeline that are inherently highly serial and very difficult to thread.
I have a i7 2600k.
Your need to read this and this.
I'm no Intel fanboy, but you're forgetting 2 important things, and they're both the additional cores on an 8700k vs a 2600k :)
But as Rroff says above, some things just don't thread. It's up to game developers to implement parallel processing properly, and if they haven't, then you'll find Threadripper only uses 1 thread at it's cap of 4.2ghz... You have to watch the load over all cores, not just your max clock speed :)
Where Threadripper might come in handy is for a FUTURE game such as Star Citizen, but at the moment on my 1950x in Battlefield 1 64 player Sinai Desert @ 1080p, I'm seeing 20-30% CPU usage and 4.6 GB RAM usage. CPU reaches 60% at the loading screen though. :)
