If you won the lottery rig
14 Aug 2011
Ok so im a bit bored so i done a quick rig of what i might get if i won x amount of millions
1200W PSU, Corsair Pro Series Gold 1200AX, Modular, 90%Eff', 80 PLUS Gold, SLI/CrossFire, EPS 12V, Quiet Fan, ATX
5 x 120mm AK-FN058 Akasa Apache Black Ultra Silent Fan HDB bearing PWM fan *OEM Fan Only
4 x 1536MB EVGA GTX 580, 40nm, 4008MHz GDDR5, GPU 772MHz, Shader 1544MHz, 512 Cores, mHDMI/DL DVI-I
2 x 240GB OCZ Agility 3 SSD, 2.5" SATA 6Gb/s, SandForce 2281, Read 525MB/s, Write 500MB/s, 45K IOPS
2 x 2TB Western Digital WD20EARX Caviar Green Quiet SATA 6Gb/s IntelliPower 64Mb Cache 8ms HDD
4 x 6GB (3x2GB) Corsair Dominator, DDR3 PC3-12800 (1600), CAS 8-8-8-24, DHX, XMP, New connector, 1.65V
Acronis® True Image Home 2011, HDD Backup & Restore Software - A Must! *Best Seller
Creative X-Fi Titanium Fatal1ty Champion Soundcard PCI-E -
EVGA Classified SR-2, Intel Xeon 5520, S1366, DDR3 Triple Ch, 4 Way SLi, SATA3/USB3, HPTX
2 x LG BH10LS30.AUAR 10x Blu-ray Writer, 16x DVD±R, 8x +RW, 6x -RW, 12x RAM - Retail + Software
Lian Li PC-P80B Armoursuit lack Super Full Tower Aluminum Case Without PSU
Microsoft Windows 7 Ultimate 64 Bit SP1 Operating System, Single, - OEM
l
2 x Prolimatech Armageddon Ultra High End CPU Cooler, 6 Heat Pipe, Intel Socket LGA 775/1366/1156/115
2 x intel Xeon X5680, Westmere Six Core, 3.33GHz, 12MB Cache, 130W
Total£7,053.30
I know you lot can do better than me so give it a try,
Ps i haven't won the lottery so im not getting this rig :) ....... Yet lol
lol every ones a critique
;) Welcome to the internet
I would just have a wall of monitors hooked up to a COW ( cluster of workstations) I don't have the spare hours required to spec everything up, but I have a fair idea on how it would be :D
as an electrician i could join 2 1200 togher but i doubt that would cover it to be honest
just use the silverstone Temjin Tj11. that has room for two power supplies.
however, 4 590's wouldnt work because a 590 is two 580's on one card and nothing supports more than quad SLI.
unfortunatly my 'if i won the lottery' computer wouldnt really impress many people as i just couldnt justify spending masses on the PC. of course i'd spend a lot, but there would be a lot more i could get that i wouldnt
YOUR BASKET
1 x Asus MARS II GeForce GTX 580 X2 3072MB GDDR5 PCI-Express Graphics Card £1199.99
1 x OCZ RevoDrive3 X2 240GB PCI-E SSD - (RVD3X2-FHPX4-240G) £569.99
1 x Benq XL2410T 24" TRUE 120Hz 3D Widescreen LED Monitor - Black £284.99
1 x Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail £239.99
1 x Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard £169.98
1 x Silverstone Raven 2 RV02W-EW Evolution Windowed Case - White £155.99
1 x OCZ ZX Series 1000W '80 Plus Gold' Modular Power Supply £154.98
1 x NVIDIA 3D Vision Kit with Duke Nukem Forever £107.99
1 x Asus Xonar D2X 7.1 PCI-E Sound Card £82.99
1 x LG BH10LS30 10x BluRay-RW / 16 x DVD±RW Drive - Black (Retail) £78.98
1 x Thermalright Silver Arrow CPU Cooler (Socket LGA1366/LGA1155/LGA1156/LGA775/AM2/AM3) £50.99
2 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £47.99 (£95.98)
1 x Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £39.98
Total : £3,259.45 (includes shipping : £22.20).
it really would be one sexy beast though :)
To be perfectly honest, if I won the lottery I would be too busy sailing my luxury yacht round the med than worry about choosing PC components.
lol, did you just pick out the item that cost the most for each category?
to be honest ....yes but that's the fun in it isn't it,knowing i would never get this
and lets face it even on a footballers wage for the rest of your life you cant really justify 7k on a computer can you. But it saved 10 mins of boredom
Some guy on this forum has a micro-ATX Silverstone Fortress build. It looked amazing. I don't even know what the specs were, but if I won the lottery, I'd buy several of them.
i'd just keep my current rig...
amd 1055t
4gb of ram
gigabyte 890gpa-ud3
nvidia 460gtx
but swap out the graphics card and buy 2 more monitors , no point beeing silly nothing really needs it
well, if thats what your after, this is probably the most expensive thing you can buy that will work without spamming stuff:
YOUR BASKET
1 x OCZ RevoDrive3 X2 960GB PCI-E SSD - (RVD3X2-FHPX4-960G) ** PRE-ORDER** £2649.98
2 x Intel Xeon X5680 3.33GHz (Westmere) (Socket 1366) - Retail £1368.50 (£2,737.00)
1 x EVGA Classified SR-2 Intel 5520 (Socket 1366) DDR3 Motherboard (270-WS-W555-ER) £529.98
1 x Lian Li PC-P80N Full Tower Case - Black £349.99
1 x Corsair Professional Series AX1200 High Performance 1200W Modular '80 Plus Gold' Power Supply (CMPSU-1200AXUK) £234.98
1 x EK H3O Watercooling Kit - Supreme HF 360 **EN Nickel Plating** £184.99
1 x Asus Xonar HDAV1.3 Deluxe Sound Card £179.99
1 x Pioneer BDR-206MBK 12x BDXL BluRay RW / 16x DVD±RW Drive - Black (OEM) £159.98
4 x Corsair Vengeance 12GB (3x4GB) DDR3 PC3-16000C10 2000MHz Triple Channel Kit (CMZ12GX3M3A2000C10) £154.99 (£619.96)
1 x Highpoint RocketRAID 640 SATA 6Gb/s Raid Controller Card - PCI-E £134.99
1 x Western Digital Caviar Green 3TB SATA 6Gb/s 64MB Cache - OEM (WD30EZRX) £124.99
1 x Aqua Computer Aquaero 5 PRO LCD Fan-Controller £109.19
1 x IC Diamond 24-Carat Thermal Compound (4.8g) £12.98
1 x Aqua Computer Aquaero 5 PRO Aluminum Front Bezel - Black £8.98
1 x Akasa Hard Drive Dampener 3.5" - 5.25" Conversion £6.98
1 x Akasa AK-MX002 PSU and Fan Noise reduction Kit £3.98
Total : £9,269.18 (includes shipping : £16.85).
you could make it even more expensive by choosing your own stupidly expensive watercooling system for the processor, but i really cba with that.
even if there was a waterblock that fit the Asus mars it would be illegal to use one because that card looks AMAZING
*edit*
stuff will now fit inside the case (although im sure stulid will spend ages looking for some way in which it wont work, too many PCIe cards probably)
I've seen it quite a few times on these forums now, how do you copy your basket to the forum with the clickable links and yellow price tags?
Is it just a manual edit? or am I missing something
