Ignition/Turbo Timer Help!
13 Nov 2002
Scotland
Right..
Ive got a bit of a problem here... hopefully someone can help.
My car has a japanese turbo timer/remote start that didnt come with the remote. My plan was to remove this today.
I first started by finding out where all the cables went behind the dash, and i removed the aerial for the unit. Power then died on the car... no electrics.
I have two pics of the situation currently... can anyone help with removing this from the iginition? Quite simply i dont want it...
From the pics you can see the unit with one black wire heading for the aerial.
Another black wire to earth (i assume) on the right.
The loom has 4 wires within it that then head to the ignition on pic2.
got make of turbo timer? how many wires are on it? what colour are these? and what colour wires are they connected to?...
i cant help with the removale.. but im sure with all the possible info.. someone will b-able to :)
Yep.. the main wires heading into the ignition are green red blue & white.
the earth is the black...
The make is one ive never heard of, its called a Starbo RS601
well im not sure which wire goes where.. lol
but one must be from your battery.. removing the aerial could have set off some kind of tamper thing? to stop car theft..
but the way it must work is.. constant supply coming from battery and the output going to other side of your ignition switch and to starter relay.. bypassing the ignition
are the cable spliced onto original ones? or have they been cut totaly?
yeah, i reckon all will be fine if i remove the unit... it seems to be spliced into existing wiring... so hopefully all should be well if i remove it and tidy up the wiring..
Agreed?
