IIS 7 - Setting a Default Page
18 Oct 2002
The Darkside
I'm using IIS7 and I am trying to set a homepage for a particular folder using a php file as the main page. For example if I went to the following url:
http://localhost/test
It would open up index.php which is located in the folder test.
I remember doing it in previous versions but since I am new to IIS7, its confusing me.
I know its something simple but its the simple things that wastes your time.
Cheers.
Found It.
As soon as you post for help, you find the answer a second later. :o
I wish I could delete this thread myself.
