31 Aug 2009 at 22:28 #1 suarve suarve Soldato Joined 8 Oct 2005 Posts 4,184 Location Midlands, UK Hi, I want to xampp instead of iis on vista Other than the following, is there anything else i need to do, to totally disable iis? - disable startup of iis service - remove iis from add/remove windows components Thanks
31 Aug 2009 at 22:39 #2 theheyes theheyes Soldato Joined 17 Jan 2007 Posts 8,944 Location Manchester Nope, you should be good to go.
