IIYAMA 24" LCD MONITOR DOWN TO £152.98 INC. VAT - UK's LOWEST PRICE
17 Oct 2002
Stoke
Our second monitor deal for the day is perfect for games and Blu-ray movies with a Full HD resolution and low 2ms response. At just £152.98 Inc. VAT it's also the UK's lowest price.
Iiyama ProLite E2407HDSD 24" Widescreen LCD Monitor @ £152.99 inc VAT
The ProLite E2407HDSD is HDCP compliant and features true 16:9 High Definition 1920x1080 native resolution. Complimented with a blistering 2ms response rate and 60000:1 Advance Contrast Ratio the E2407HDSD really is, in a class of its own. Opticolour automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity. Finished in a stylish Piano Black design, the E2407HDSD is sure to stand out amongst the crowd!
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 60000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- Dimensions: 560.0mm x 404.5mm x 220.0mm
- Weight: 5.0kg
- Warranty: 3 Years On-Site
Only £152.99 inc VAT.
ORDER NOW
Is this better in terms of colour than my Samsung 226BW?
Could not personally make a comparison to the 226, but after some tweaking of the factory settings and having used some card colour swatches that come with quite an expensive bit of mac software, I was very impressed by the colour reproduction.
I'm very happy with mine (using it for photograph restoration and a bit of gaming) and my daughter uses the buiness model (with the adjustable stand and HDMI port) in her office as a professional wedding photographer and she's also very happy.
