Careful if your thinking of one of these. I am waiting for my 3rd one now as the first two have had exactly the same faults as these two reviewers. Small dead semi circle, bottom right.
Jack1994
I have received 2 of these monitors and both have the exact same fault. They both have 2 large damaged circles on the display that look as though the screen has taken a hit. The second monitor was a replacement for the damaged first one. Possibly a faulty batch or just badly made.
![](https://scan.ugc.bazaarvoice.com/static/0758-en_gb/link-facebook.gif)
![](https://scan.ugc.bazaarvoice.com/static/0758-en_gb/link-linkedin.gif)
![](https://scan.ugc.bazaarvoice.com/static/0758-en_gb/link-twitter.gif)
Posted bySMobius
20 January 2018
I had exactly the same experience. black arcs of dead pixels at the bottom right corner centred on the exact corner. the first one had a cracked case. The replacement had no crack on the case but the fault was identical. If you left the screen on the pixels slowly came back to life but reset when the screen was turned off.The third screen I was sent works perfectly. this seems to suggest they had manufacturing issues.
Jack1994
Posted bySMobius
20 January 2018
