Hi all,
Little bit stumped at the moment. Just fitted a new vega 64 into the pc and been tinkering with various settings as one does. Cut a long story short I went to check to see if freesync was active which it was not (greyed out) on monitor settings. Whilst trying to change this I managed to Osd locked the monitor and now cannot unlock. Looked on the online manual and says to press menu then the arrow up symbol for 5 secs. This does not work. Tried all sorts and any suggestions would be great.
Not keen on buying a new monitor if I don't have to
Worse case scenario I would need suggestions for a good monitor to upgrade to.
Thanks
Steve
Thanks
Steve
