Iiyama g2773hs & Amd Fury..how?
23 Jun 2004
Blackburn
Hello,
I currently have an Iiyama g2773hs 1080p 120hz monitor and I'm looking to upgrade my gpu to an Amd Fury. Problem is my monitor doesn't have a dp connection, only vga, hdmi and dl-dvi. I would like to change my monitor in the future to something with freesynce, 1440p and 144hz but can't afford both monitor and gpu at the mo.
Is there an adapter I could get in the meantime that would allow me to connect the dp on a Fury to the dl-dvi on my monitor and run my screen at 1080p and 120hz?
Sure, there are such adapters, but problem is they'll cost you a lot. Search for 'active DP to Dual Link DVI converter'. I can't link anything because a lot of it is competitor sites for OCUK.
