- 17 Oct 2002
- Stoke
For those of you looking to try out the new multi-touch technology in Windows 7, we've got a new panel for you which is substantially cheaper than the SX2210T from Dell.
Iiyama ProLite T2250MTS Multi-Touch 22" Widescreen LCD Monitor @ £247.98 inc VAT
The ProLite T2250MTS 22" Touch Screen is an early adaptor of the new MultiTouch Technology. Based on the latest Optical sensor, the T2250MTS is Windows 7 Compatible and ready for the emerging business and consumer software packages. The innovative T2250MTS lets you browse the web, email and draw while working on multiple screens, docking and or typing on the on-screen keyboard. You can scroll and rotate pictures, draw, zoom in and out using certain tap, flick, grab and pincer gestures. The multi-touch is not only fast but also fun to work with. The panel features a High Definition 1920x1080 resolution with a 5ms response time. Analogue and DVI inputs are available for flexible connectivity along with USB for the Touch Interface.
- Multi-Touch Technology (REQUIRES WINDOWS 7 HOME PREMIUM & ABOVE)
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 1000:1
- Brightness: 260cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 513.0mm x 419.0mm x 263.0mm
- Weight: 7.7kg
- Warranty: 3 Years On-Site
Only £247.98 inc VAT.
ORDER NOW
- VESA Compliant
- Weight: 7.7kg
ORDER NOW
