13 Jun 2012 at 21:59 #1 fantasticCG fantasticCG Soldato Joined 29 Feb 2012 Posts 2,908 Location London Does anyone know how good this is Iiyama ProLite G2773HS 120Hz 27" Widescreen LED 1MS Monitor???
16 Jun 2012 at 05:44 #2 fantasticCG fantasticCG Soldato OP Joined 29 Feb 2012 Posts 2,908 Location London Anyone?
16 Jun 2012 at 12:56 #3 melmac melmac Soldato Joined 19 Dec 2010 Posts 12,848 there is a thread on this monitor if you search. http://forums.overclockers.co.uk/showthread.php?t=18393652&page=5&highlight=g2773hs
16 Jun 2012 at 12:58 #4 Relentless81 Relentless81 Soldato Joined 18 May 2010 Posts 12,885 There is a thread on it, I have one, its really good, glad I went for it over the Benq and Samsung 24"
16 Jun 2012 at 21:03 #5 du5t du5t Associate Joined 11 May 2012 Posts 38 Relentless81 said: There is a thread on it, I have one, its really good, glad I went for it over the Benq and Samsung 24" Click to expand... I just picked up one of these yesterday... pretty happy so far. My Benq 2420 (also an excellent monitor) had a fault so went back... I ended up pulling the trigger on this 27 instead at the last minute! As you've had one for a while - what settings are you using? Thanks
17 Jun 2012 at 11:29 #6 Relentless81 Relentless81 Soldato Joined 18 May 2010 Posts 12,885 I'm just using the default settings, got used to them and seem fine to me
18 Jun 2012 at 19:08 #7 Will Gill Will Gill Don Joined 18 Oct 2002 Posts 56,777 Location Cornwall I have one too on the machine in my flat, it seems pretty awesome certainly gets a thumbs up from me change the overdrive from 0 to +2
