Hi there
We now have an ideal product for business and education in the form of the iiyama T2250MTS MultiTouch LCD Monitor:-
Iiyama ProLite T2250MTS 22" Widescreen MultiTouch LCD Monitor - Black @ £222.99 inc VAT
The ProLite T2250MTS 22" Touch Screen is an early adaptor of the new 'MultiTouch' Technology. Based on the latest Optical sensor, the T2250MTS is Windows® 7 Compatible and ready for the emerging business and consumer software packages. The innovative T2250MTS lets you browse the web, email and draw while working on multiple screens, docking and or typing on the on-screen keyboard. You can scroll and rotate pictures, draw, zoom in and out using certain tap, flick, grab and pincer gestures. The multi-touch is not only fast but also fun to work with. The panel features High Definition 1920 x 1080 resolution with a 5msec response time. Analogue and DVI inputs are available for flexible connectivity along with USB for the Touch Interface.
The T2250MTS displays how the latest technology allows you to zoom in and out, scroll, stretch, highlight and rotate on an amazing range of platforms on your PC by using certain tap, flick, grab and pincer gestures.
For maximum comfort the multi-touch comes with a special pen to write with on the screen. There is a special storage place for it at the side of the cabinet. And analogue and DVI inputs are available for flexible connectivity along with USB for the Touch Interface.
Specification:-
- Diagonal: 22"
- Touchtechnology: optical, multitouch (2 compatible touch points), activated by finger or stylus
- Panel: TN
- Display area: h x w 268.11 x 476.64 mm; 10.6" x 18.8"
- Response time: 5 ms
- Contrast: 1000:1 typical
- Brightness: 260 cd/m² typical
- Viewing zone: horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 85°/ 75°
- Display colour: 16.7 million
- Pixel pitch: h x v 0.248 x 0.248 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 31 - 82 KHz
- Vertical sync: 56 - 75 Hz
- Synchronization: Separate Sync
- Aspect ratio: 16:9
- Light transmittance: 88%
- Analog input connector: D-Sub
- Digital input connector: DVI-D
- HDCP: yes
- Inputs: USB
- Plug & Play VESA DDC2B™
- Controls: On-Screen-Display in 8 languages (EN, FR, DE, IT, JP, PL, NL, RU) and 5 front controls (Power, Auto, Scroll up/ Brightness/ Contrast, Scroll down/ Volume, Meu/ Select)
- User controls: brightness, contrast, image control (auto adjust, H. position, V. position, clock, phase, sharpness), colour adjust, OSD control (H. position, V. position, timeout), other (language, input, speaker volume, information), reset, exit
- Speakers: 2 x 1 W (Stereo)
- Anti-theft-device: Kensington-lock™ prepared
- Safety: CE, TÜV/Bauart, VCCI-B
- Tilt angle: 20° up; 3° down
- VESA mounting: 100 mm
- Colour: Black
Only £222.99 inc VAT.
ORDER NOW
Specification:-
- Diagonal: 22"
- Panel: TN
- HDCP: yes
- Inputs: USB
- Colour: Black
ORDER NOW
