- 25 Aug 2010
looking for some advice on fitting a pc into an expedit shelving unit...
trying to work out if it's feasible to fit everything i need into one of the bits on my expedit bookcase
there are all ready inserts to fit the shelf http://www.ikea.com/gb/en/catalog/products/40166569
33x33x37 cm - i was thinking of either trying to cram everything into one, but then thought maybe putting the psu in a seperate one to help reduce the temps and need for venting.
would likely rip up an old case for mounting etc, but wonder if anyone could recommend a good way or minimising vibrations and noise when trying to fix everything in... or if i should just ditch the idea completely!
