I've built a single 50cm wide pax wardrobe with a mirror door it does feel flimsy so will need fixing to the wall. However on fitting the door when closed the gap at the top is a lot wider than at the bottom and no amount of adjusting the hinges will close it. Anyone have any suggestions or is the door/ frame likely to be warped ?
