Scythe said:Hi I got Sturmovik + Forgotten battles, does any play it on this forum and have any pointers for online etc?
Dj_Jestar said:<o/
You'll need Pacific fighters as well to join Online, and use HyperLobby, not that gash default online program
Yak-3, circa 1943 is a good starter plane.![]()
cant comment on the yak-3 as i've not flown it but.............. since the last two patches the bf109's have become much easier to handle.dealing with engine torque is a little tougher but imho they have become almost impossible to stall.landing has to be precise.William said:Yak-3 is the easiest plane to fly last time I played, LA-7 is too boom and zoom. Bf-109s require a bit more finesse because they spin like a mofo but are potentially better.
it is in fact a bit uber in the game as it hardly bleeds any E in a turn.you can jank the stick over and pull til you start to blackout and maintain speeds far in excess of anyother aircraft.the LA is the classic "turner and burner".landing is childs play.
It's easy to BnZ in the LA7.eddie_slovik said:cant comment on the yak-3 as i've not flown it but.............. since the last two patches the bf109's have become much easier to handle.dealing with engine torque is a little tougher but imho they have become almost impossible to stall.landing has to be precise.
the LA-7 is most definately NOT a boom and zoom type aircraft.you could try but be prepared to lose your wings at 750kphit is in fact a bit uber in the game as it hardly bleeds any E in a turn.you can jank the stick over and pull til you start to blackout and maintain speeds far in excess of anyother aircraft.the LA is the classic "turner and burner".landing is childs play.
i take your point about being able to BnZ at any speed but the LA's performance tails off above 3000m.trying to get back up to a safe altitude with a 109 on your 6 would be diceyDj_Jestar said:It's easy to BnZ in the LA7.
750kph is more than enough speed, you can bnz at 500. It's the climb rate that really matters for BnZ, and the LA7 has a pretty good one at that
It's the fastest Ruski prop-plane.
However nothing beats the 190 for BnZ.. simply sublime plane, but far from a beginners aircraft!
