iLife (iMovie)
9 Jun 2005
A Beer Garden in the Toon
When I first got my mac it had iLife installed on it. I did a format and chose not to install it again.
Now I want to use iMovie but I can't seem to find it on my Leopard install discs? Was this something that came pre-installed as a trial or do I need to do a full format to install it?
Check the second disc
I think it's the first disc.
Put the first disc in and it should give options on the disc to 'Install OS X and Bundled Software' or 'Install Bundled Software Only'. Obviously choose the latter.
At the beginning of the installation it'll ask for the second disc to be inserted and then back to the first again - and will install the iLife goodies.
You can only start the installation from the first disc, despite the files being on the second one (which is highly irritating sometimes).
Ahh, I did start the bundled install option first, but when it didn't give me a choice of what I wanted to install and started installing 'CPU Help files' I figured I'd got it wrong. Installing now.
Thanks guys
