Illustrator/Corel Draw turorial sites
18 Oct 2002
Are there any good tutorial sites for illustrator/corel draw similar to the goodtutorials.com site for photoshop.
Main reason is i design decals for scale models, and used to use photoshop, but recently got an alps printer and with it been a thermal wax/resin printer the images need to be high res
So most use vector apps, and iv been trying to get to grips with illustrator using the pen tool but its completely different in the way it works compared to the photoshop pen tool. (ie for doing curves such as a wheel arch cut out in photoshop i would simply dray a straight line and add points to in the bend/curve the line.
Tried this in illustrator and it reacted completely different.
If youve got MSN, please feel free to add me. Im by no means an Illustrator guru, but Ive been using it quite heavily for the last 5-6 months, and I think ive got the hand of it quite well. Its an amazing program once you get used to it.
